Home > Technical (L322) > Air Con, randomly goes really cold
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Any ideas why air con would suddenly go really cold?
I have my heating turned up (hot/cold dial to full heat and temp set to max) no problem. If i set temp to around 22 at some point it suddenly swaps to pushing out really cold air?? turn to full and heat comes back? Evil or Very Mad its really irritating ....... 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #180356 29th Mar 2013 8:57pm
Bienbn
England 2004 Range Rover Vogue Td6 Java Black
is the Wife in the car? that's usually what f**ks around with the settings in mine....
Post #180357 29th Mar 2013 9:09pm
dan_uk_1984
Could be an airlock in the system, anything other than the coolant level at max can introduce bubbles into the system that then group and can cause issues. Usually giving it a bit of welly increases the flow and disperses the airlock.
I also notice you have LPG - depending on where they have tapped into the coolant pipes you could find this is causing the problem (the water will choose the path of least resistance etc)
The other thing, if it only happens at lower revs is the Auxiliary coolant pump could have failed, quite common on BMW's around the same age and it is a BMW part...
Post #180359 29th Mar 2013 9:18pm
twhincup
Rolling with laughter just told the wife its her fault 2007 3.0L Diesel VW Touareg SE
Post #180361 29th Mar 2013 9:20pm
twhincup
thank you dan, sounds complicated so as summer is on the way, cold is fine by me Smile 2007 3.0L Diesel VW Touareg SE
Post #180362 29th Mar 2013 9:22pm
