![]() | Home > Maintenance & Mods (L322) > auto lights |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
dan, how do you get this info of the microcat.
From initial research the later LCM is backwards compatible but not vise versa if that makes sense? This may of course be dodgey googling. I might try and find a new LCM & Switch just to give it a punt. Daveo Not sure what you mean get the info out of microcat? Dan ![]() |
hi dan, you had jem email pm his reg and then you got the part number of what unit was fittet, how did you get that from his reg, are you a dealership, is this info avalible to any one,ie can i find out whats on my car
Download Microcat It's a bit of a faff to get working, but worth it. Dan ![]() |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Slightly veering off topic - but has anyone else noticed that when the light switch is at the auto position, the front/ rear foglights will not operate (even if the lights are on) ? |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
Maybe on a 06MY. My 2007MY works fine. Only the lights are on but thats logic. |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
Yes I can't flash my foglights at the tools driving with them on when on Autolight setting. 15MY SDV8 Vogue SE |
I think automatic headlights retrofit is possible:
come on dan, tell me more,
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
Is this the auto light switch you need?
Check that link above... ![]() |
Possibly, I'd be happier with a pre-facelift one to make sure they didn't change the wiring. I'll have a look at the part number later. You can buy that switch brand new from Britcar for £42 so that guy who wants £40 for a used one is having a laugh! UPDATE: Just bought that switch from him for £20.00. Bargain. ![]() |
hi dan, please could i have the part numbers when you have sorted them out
Mine says SW12 - Does that mean its on V12? So does that mean it will already run autolights with just the switch & the rain sensor inc light sensor? Dan
