TDV8 Engine misfire and misting rear lamps | |
My Vogues SE is coming to the end of the 3yr factory warranty (I have a fourth year extension). I booked my car into Guava later in March for MOT, annual service and to fix an engine fault, missing on start up and occasional hesitation ( I suspected an injector had gone).
William the service desk guy suggested I drop it in on the way home to pop it on the diagnostics machine. Tim the workshop manager took it in to the shop and confirmed it was number 2 injector gone and it needed to be in for 5 hours for that job alone. However there were no other significant fault codes' ', just low voltage on lights - they all do that.
I had pointed the same issue out to Hunters on a post purchase fix-issues visit and they could not identify the fault and said Customer needs to demonstrate fault . Here is a clear example of a different level of maintenance and attitude towards the customer. Having used Guava for servicing on my Disco 3, I new they listened to the customer and paid attention to detail, and above all fixed things.
While I was their I aksed Tim about the fogging of the rear lights, I had photos of fogging from the side. He said get some from the rear showing the fog obscuring the brake or indicator, which I will do at they right point, they can then be swapped for the modified ones.
Chatting a bit more, Tim said they had recently had a TDV8 sport in with a failed turbo, before I new it I was taken into an office to be shown a photo of how it is done, the recommended Land Rover way - body off! They had lifted the body up, exposed chassis and engine to get to the rear of the engine to replace the turbo. It took them a little longer than Land Rover allowed (10 hours) due to an Overfinch body kit and the desire not to bust anything on parting the body. I hope to get a copy of the picture and I will post it. Hunters mechanics popped over to have a look, as they had never done it and don't have the right hoist for the body any way.
I'll report back if everything is sorted on mine at the end of March. 2018 Range Rover Autobiography
2010 Land Rover Freelander XS
1959 Series II
1950, 1952, 1954. 1955, 1957 Series I
1952 Minerva Ambulance
