Home > Technical (L322) > Wheel Arch Removal For Vehicles Fitted With TPMS
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
As title suggests are there any complications involving removing the wheel arches (To gain access to FBH) on vehicles with TPMS system fitted, IIRC the arch has hall effect sensors somewhere in them and RAVE procedure is pre TPMS introduction.
Thanks.
Post #179241 23rd Mar 2013 1:42am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
The TPMS initiator is attached to the arch liner, there should be enough slack in the cable to allow you to unclip the wires to the initiator once the arch liner is loose 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #179472 24th Mar 2013 12:53pm
Katash
Thanks
Post #179516 24th Mar 2013 5:40pm
elmer
2008 Range Rover Vogue TDV8 Java Black
hi,
what is TPMS initiator? are these related to the system pression tires
Thanks
Post #179718 26th Mar 2013 12:33am
Andy_J
The initiators are oval shaped units fitted in each wheel well. They send a request signal to the pressure sensors in the wheels. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #179750 26th Mar 2013 2:29pm
