![]() | Home > Technical (L322) > RR S/C Suspension v's TDV8 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
why would you need to do that? i thought its just lowering the body [if that makes sense] ... - .- -. Y. O. L. O. . |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2604 ![]() ![]() |
Seriously? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6746 ![]() ![]() ![]() |
Come on then, you've obviously got some wisdom to share, so spit it out! |
when my td6 lowered to motorway height from standard ,did the alignment change somehow then... |
How could it not have, particularly in camber? It doesn't have solid axles or equal-length wishbones.
Well that's cleared things up for me! |
Can't see 10mm making a huge difference, but it would be interesting to see how it changes things.
i lowered my td6 by 10mm and although i didnt do many miles after that ,i didnt notice any abnormal wear on the tyres..
Mine has been lowered using the IID Tool for a year and I've also had no abnormal tyre wear........... Got - 2017 SDV8 Autobiography in Loire Blue
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
When I raised, my previous D3 (+30 mm) I did get the alignment done, that goes without saying.
