![]() | Home > Maintenance & Mods (L322) > Engine tuning |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 816 ![]() ![]() |
anyone tried this?
Think there have been a few …. |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Had mine (TDV8) modified last year by JE. The care felt totally different afterwards, a lot smoother and gearbox doesn't drop down a gear as often. Makes towing my large twin axles caravan a breeze.
Andy it wont do that, thats the gearing. It will just make you get to 80 quicker |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 ![]() ![]() ![]() |
Might not drop the revs, but might reduce the noise a little or increase MPG as it'll change the fuel/air mixtures and potentially use less fuel. |
The upgrade Improves the torque at lower revs so the gearbox doesn't need to change down as often when you press on the loud pedal. The gearbox ecu takes multiple feeds, not just speed and revs is my understanding. |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 965 ![]() ![]() ![]() |
so it would sound l / feel like its not straining at the top end? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35530 ![]() ![]() |
save your money Andy, i wish i did...my remap was a waste of time but removing the egr valve and blanking it was a good move and cheaper as well...
cheers stan, to be fair its easy at 80.... 90 is a different issue |
90-110 shouldnt be too bad. 110+ is the hard bit as its just out of puff then. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
@Andy, the egr blanking helps by having cool air going into the combustion area which helps with mpg and smoother running ...i did it quite easily.. ... - .- -.
Stan
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
Mate.
robjp Member Since: 14 Jan 2013 Location: North Wales Posts: 104 ![]() ![]() ![]() |
Regarding TD6 chipping ...
