Home > In Car Electronics (L322) > Homelink
Rich86
United Kingdom 2009 Range Rover Vogue TDV8 Nara Bronze
Homelink
Does anyone know whether Homelink was fitted as standard on the L322 Vogues from 2002 for the UK market? Ive seen them on US models and they're shown as 3 buttons on the interior mirror but unsure about the UK.
Post #177494 14th Mar 2013 8:05am
Don't know when they came as standard but I have Homelink on mine think it may have been around the 06/07 mdl years but I could be wrong ====================================
Post #177497 14th Mar 2013 8:10am
Charmer
Not fitted to my 2007 Vogue SE.
Post #177504 14th Mar 2013 9:02am
only fitted to about 2010 onwards i believe... ... - .- -.
Post #177505 14th Mar 2013 9:08am
I believe they are fitted to the 09> facelifts and special order before that year... Thumbs Up
Post #177511 14th Mar 2013 9:45am
ebajema
Have it on my SC but that is a North American Spec. MY 2010 5.0 SC Galway green and sand interior!!
Post #177512 14th Mar 2013 9:53am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Got it on mine. Tried to synch it with my gates but didn't work, need to spend more time on it. 2007 TDV8 Vogue SE Java Black
Post #177515 14th Mar 2013 9:56am
Post #177521 14th Mar 2013 10:09am
taskam
Thumbs Up I'll give it another try 2007 TDV8 Vogue SE Java Black
Post #177561 14th Mar 2013 12:59pm
Havank
United Kingdom 2003 Range Rover Vogue Td6 Java Black
forget it
its not a rolling code. most gates are rolling code
Post #177570 14th Mar 2013 1:58pm
taskam
Yeh my gates are rolling code, but I thought Homelink could handle that. If not that would explain it 2007 TDV8 Vogue SE Java Black
Post #177587 14th Mar 2013 3:20pm
Charmer
Try contacting Homelink here http://www.homelink.com/
I had a similar problem with a Mercedes. Each country uses slightly different frequencies and you need to ensure the Homelink unit is programmed for the right country.
There is a procedure for changing the Homelink frequencies/Country codes by pressing various buttons in a sequence.
The Merc was set up for Germany by default. Once I changed over to UK frequency it worked with my gates & garage doors (which are rolling code).
Post #177593 14th Mar 2013 3:45pm
taskam
Thumbs Up will try this weekend 2007 TDV8 Vogue SE Java Black
Post #177610 14th Mar 2013 4:38pm
Rich86
Cheers guys.
Post #177625 14th Mar 2013 5:39pm
Lars T Madsen
Denmark 2007 Range Rover Vogue SE TDV8 Java Black
I have it on my 07. The car was specified for the German market, and works fine.
Post #177648 14th Mar 2013 7:49pm
