Home > Technical (L322) > Sick of it now |
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 |
I just want it at factory settings, unsure what to say to the Indy as he is adamant it's correct |
13th Mar 2013 9:56pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Doesn't sound right, but you have to allow a 10mm tolerance, the car won't or can't be made to adjust within that range. The IID tool won't fix this either, unless you get everything lined up at a lower height. So side to side you are within tolerance levels but overall hieghts do appear to be wrong.
13th Mar 2013 10:01pm |
Hi I can only find overall heights in the owners manual, I might just take a copy of this table down |
14th Mar 2013 1:12pm |
Well my Indy has just rang me back and said that its at the correct height and the reason it's sitting lower is because I have 20" alloys on it and they didn't come from the factory with 20" wheels, honestly who's he kidding! I served my time at the main dealer and worked with him so its making it awkward questioning him, not sure what to do, he reckons the only solution is going back to 19" wheels? Surely you can just enter a different value? |
14th Mar 2013 5:09pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1698 |
I'm no expert here and I;m not sure if wheel size makes a difference. I would have thought the rolling circumference would be the key rather than the rim size personally.
14th Mar 2013 7:04pm |
Bit of advice please guys, just been down to see the Indy and explained that its only sitting 1cm above access height at normal road height, he said he has programmed it to 20" wheels and that's the being it comes out at, he said its because my 2003 td6 shouldn't be on 20" wheels, is that correct because I'm sure they can, he said pop it down on the morning and he will have a play with it, he said he will try setting it to 19" wheels as it was ok before, he is using autologic diagnostics, anybody else used this to recalibrate and what will work, please if anyone can help as I'm sick of it looking like its been lowered now |
15th Mar 2013 5:53pm |
Its easy I think you just need a new indy or even pay a Main Dealer should not be more than 30 minutes labour.
15th Mar 2013 5:58pm |
Well another specialist won't just do the recalibration without charging me £60 first to do a diagnostic but iv got a friend who works at landrover with the snap on diagnostics and he reckons he can recalibrate it but not till next week. If my Indy is just putting 20" wheels in on autologic is there anything else he can do? Seems strange that its setting it so low? Anybody use the autologic? |
15th Mar 2013 6:01pm |
SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
H Durham,
18th Mar 2013 6:29pm |
