![]() | Home > General (L405) > Leather seats |
If it were me I'd buy the best I could afford otherwise you will always regret having not gone for the Vogue SE |
Mizengeo Member Since: 07 Mar 2013 Location: Reading Posts: 47 ![]() ![]() |
Agree - but where do you stop. I went to Land Rover planning to pay £50k for a discovery - I'm already 50% over planned budget with the vogue. Not worried about fancy headlights, soft close etc. - would rather spend money on sunroof, winged headrests etc. Geoff |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 ![]() ![]() ![]() |
Hi, difficult choices as ever. I had both Vogue and Vogue SE in the L322 which had similar choices. Semi-analine is much softer but could also be more vulnerable. In terms of comfort the Vogue was fine for 20k miles a year.
Better still buy it for me Vogue spec fine |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 ![]() ![]() ![]() |
Same dilemma I had when choosing vogue or SE on the old version. All I can say is there was a big difference in the leathers back then & I went the SE route & never regretted it. You will use the extra's you get as standard and consiquently would miss them when you come to change. I suspect most SE or AB owners wouldn't go back to a standard Vogue |
Thanks for your thoughts. If Oxford leather is more durable that sounds good, wonder if you can feel the benefit of softer leather through a pair of jeans - I'll have to try. Would have to be a lot better though to justify the additional £6,500 for the SE - actually £5,000 because I would be buying the ACC if I didn't get the SE. Oxford leather looks likely I think - seats are perforated and cooling is an option. I've had leather seats before but not found the need for a cooling system - in the UK do you think they're worthwhile - interested to hear from the forum on that. Geoff |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 923 ![]() ![]() |
If you look at it another way, either leather option will be vastly superior to anything you'll find in another Land Rover product, whether that be a top-end RRS or a Discovery.
I'd say, go for the combo you like best (if the budget allows for that). In my experience, most "extras" don't yield a higher second hand price the further you get from new. So if you intend to keep the car for some years, the return on investment so to say will be getting less and less.
montpellier Member Since: 31 Jul 2010 Location: Cheltenham Posts: 52 ![]() |
http://www.carpages.co.uk/land_rover/range-rover-22-10-12.asp
Thank you for all the helpful posts. I'm going to stick with the Vogue and Oxford leather. Not sure whether or not to get climate seats. In a climate like the UK is it necessary - do you use it regularly if you have it? I understand the cooling comes from cold air but where does it come from - is it plumbed into the cars air con? When you have climate seats does heat come from an electrical element (as in my Disco 3) or is it from air blown through? If warm air, is that a better effect than the electrical element in my Disco 3? Geoff |
johnson1 Member Since: 30 Aug 2010 Location: South West Posts: 519 ![]() ![]() ![]() |
The climate seats are a must IMO. I use the cooling function in mine a lot - not just in summer.
+1
Thanks - if I can still change the build I'm going to get climate seats Geoff |
orbtar Member Since: 07 Aug 2007 Location: Suffolk Posts: 22 ![]() ![]() ![]() |
Cooled seat function is great on a hot day but the heated ventilated seats are rubbish, they take forever to heat up, way longer than the old style element type. When they eventually get warm, you get a horrible dry air blowing up towards your face which makes you feel drowsy. Nobody has mentioned what a pain it is on the new model to turn the seats on to a low heat setting, in the old model you could turn a knob one notch, now you have to press a button, then jab at the touchscreen about three times, this can only be done if you are not reversing etc as the camera then takes over the screen. 2015 RR SDV8 Vogue SE
