Home > Maintenance & Mods (L322) > leak from rear possible diesel???
Tesh
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Ive searched the forum and cant find an answer so I think this may be a rare one
Ive noticed a film of fluid appearing on my drive over the last few days on closer inspection I discovered that it is coming from the rear of the car
ive had a light under the car and thought it was the diff seals. I jacked it up for a closer look and it seems to coming from above the diff, then dropping down on to the driveshaft then the exhaust
Ive sprayed degreaser around the area and jet washed it off
There looks like a union of some type with a electrical plug attached and I was wondering if this could be the culprit?
Anyone had a similar issue or have any ideas??
Post #175409 2nd Mar 2013 2:12pm
Tesh
Can anyone point me in the direction of a detailed parts list or drawing of the fuel system for a 2004 TD6
Post #175771 4th Mar 2013 12:50pm
Tesh
I think Ive found out what it is Thumbs Up
Its the pump for the FBH Big Cry It looks in a right sorry state, all rusty and the rubber mount that holds it in place is perished
Just got to get a price now Sad
Post #175772 4th Mar 2013 12:57pm
theres a 'online workshop manual' and a rave download links in the wiki.. ... - .- -.
Post #175773 4th Mar 2013 12:58pm
Tesh
Ive had a look on the wiki Stan and it doesnt show in great detail
Post #175774 4th Mar 2013 12:59pm
Tesh
Landrover has just confirmed a price of
£163.65+vat Shocked
Post #175775 4th Mar 2013 1:04pm
Tesh
I searched the web and its called a fuel dosing pump
There are 2 different manufacturers of these units, one being Webasto and the other is
Eberspacher The thing is, its that rusty and inaccessible, that I can't see which type it is
I can get both types for £70 from German ebay
Can anyone help???
Post #175852 4th Mar 2013 8:32pm
wats39
Scotland 2004 Range Rover SE Td6 Alaska White
According to the wiki, its a webasto fbh so would imagine its a webasto fuel pump. before replacing the pump you should check that it aint just a leaking fuel hose going to or from it. '04 td6 se
'63 land rover s2 200tdi
'04 mk indy kitcar bike engine
Post #175867 4th Mar 2013 9:55pm
Check with Duckworths Dan for price, much better than you have been quoted by LR Thumbs Up .
Post #175876 4th Mar 2013 10:07pm
