Home > Maintenance & Mods (L322) > AC failure in one year time after replacement WHY ?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
how has it failed ? and how do you know there's gas in the system....mine went due to stone damage on the condenser and it seemed like there was gas but in reality there wasnt enough. ... - .- -.
1st Mar 2013 8:33am |
We tried to fill it up and the pressure of the system was perfect and the compressor engaged as well. That is why I need to talk to an experienced AC person to see what else I can test before I do another full replacement. MY 2010 5.0 SC Galway green and sand interior!!
1st Mar 2013 8:35am |
i'd take the old gas out and fill from scratch ... ... - .- -.
1st Mar 2013 8:40am |
Why do you think that would help ? MY 2010 5.0 SC Galway green and sand interior!!
1st Mar 2013 8:43am |
if air has got into the system through a leak then it needs to have the system 'purged' and refilled with gas..
1st Mar 2013 8:58am |
You should never 'top up' the gas. It should be vacuumed out and then re-charged |
1st Mar 2013 9:00am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Sounds like a control problem with possibly a component failure rather then the "whole" system failing. |
1st Mar 2013 9:01am |
I am currently printing the workshop manual of the 2002-2005 system, hoping it is similar/same to the MY2006 system. Tonight I will hook up the Faultmate and see if I can find any issues/faults in the ECU.
1st Mar 2013 9:04am |
The other thing I noticed is that the air from the vents is "warm-ish" not as cool as the morning air coming in through the window. Which doesn't make a lot of sense to me either. I didn't notice any condensation underneath the car but that is because I only ran it for a few minutes while we were "testing". MY 2010 5.0 SC Galway green and sand interior!!
1st Mar 2013 9:10am |
Wonder if the FSR is playing up? |
1st Mar 2013 9:22am |
The fan is blasting away happily, fan speed and control are fine. MY 2010 5.0 SC Galway green and sand interior!!
1st Mar 2013 9:23am |
if you have warm air coming from the vents it does suggest that there is low or no gas in the system, is there any visible damage on the condenser.. ... - .- -.
1st Mar 2013 9:30am |
We didn't look for that yet Stan. When I go for lunch I will go and get try your replacement trick. If that works we know that we are chasing a leak. Not sure if you can buy the special leakage fluid here (they used on a car I had in Holland years ago) but will try. MY 2010 5.0 SC Galway green and sand interior!!
1st Mar 2013 9:32am |
Stan, I owe you a few drinks if we ever get a chance to meet !! Vented the system, refilled it and it is doing fine now. So we have a tiny leak (takes a year for the system to loose its coolant).
1st Mar 2013 4:33pm |
