Home > Technical (L322) > Battery Terminal "pyrotechnic charge"
IanP
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi everyone
I just joined the Forum so be gentle with me!!!
Got a quick question.
I had a flat battery so I disconnected it and put it on charge, then I read in the manual that there is a "pyrotechnic charge" on the Positive teminal and connecting the battery should only be attempted by qualified personnel.
Should I be concerned?
Also, what fun and games can I expect when I come to start it up again with regards to remote locking, key codes, immobiliser, radio codes etc...?
Any help appreciated!
Ian
Post #891 23rd Sep 2008 7:23pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Why did you disconnect to put it on charge ( i guess your charger would not reach)
Disconnected & reconnected many a time no issues
Post #892 23rd Sep 2008 7:32pm
SteveNorman
Hi,
You can reconnect with no problems.
Always disconnect the battery lead unless using an intelligent charger which doesn't exceed 14.4 volts charging voltage (older chargers can increase the voltage to sometime 16-17volts, which can damage the ecu's.
After disconnection, just start up, then turn the steering full lock to full lock to reset the steering sensor & get rid of the suspension inactive message.
Regards
Steve
Post #893 23rd Sep 2008 7:57pm
ken
Well I know about the first bit
But lock to lock is totally new on me I'll check with our techy here
Post #896 24th Sep 2008 6:38am
SteveNorman
posted from the owner's manual:
If the vehicle power supply has been
interrupted, ABS and DSC will be deactivated
(the relevant warning lights will illuminate).
They can be reactivated by driving a short
distance or by turning the steering wheel from
full lock to lock, with the engine running and the
vehicle stationary. The ABS and DSC warning
lights will extinguish when the systems are
reactivated.
regards
Steve
Post #897 24th Sep 2008 9:32am
IanP
Thanks for the advice
Got the car back on the road today, no problems. Well apart from the usual niggles from the sound system!
Did the "lock to lock" thing and it worked! warning signs went out and everything was back to normal. Left a couple of divits in the tarmac though!
Now, about that sound system, anyone else experiencing a high pitched hum at low revs? or should I start a new post?
Thanks again
Ian Gas Power - 50p a Litre!!!
Post #898 24th Sep 2008 11:57pm
ken
That text is not in mine might be a model year issue
Still the advice is given & helpful
Post #899 25th Sep 2008 7:19am
SteveNorman
Hi Ken, Thats strange, try:
2007MY page 256,
2008MY page 271,
2009MY page 249.
I doesn't really matter because if you drive a short distance it'll sort itself out anyway Smile
Cheers
Steve
Post #902 25th Sep 2008 7:52am
ken
My thoughts as well Thumbs Up
Post #911 25th Sep 2008 11:00am
