![]() | Home > Technical (L322) > HEADLAMPS stop working every 20 seconds ?? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
In the hope of removing all doubt:
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI JOE90; thanks for the drawing, hopefully as you say, it should remove all doubt. i doubt there is anything i can check on it?, so assume it would need to go on diagnostic?
Try the battery disconnection / ECU clear routine first. .
HI JOE
whilst i am trying to get to the bottom of this stupid glitch with the headlamps going out every 20 seconds |
i would imagine that was a stupid question in as much that only the small one is called the dip/main, but i thought i would double check then probably just shut up making silly comments |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35532 ![]() ![]() |
fyi, the outside lights are dual purpose...they are dip and main by using a shutter in front of the bulb....the inner lights are just for flashing and for main as well but they are not very bright.. ... - .- -.
hi stan, thanks for your reply;
