Home > Maintenance & Mods (L322) > *** 2010 in car pc project UPDATE *** |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
Intel have just brought out their NUC (Next Unit of Computing) which is a PC 4x4x2 inches in size, uses an Initel i3 chip, can have 16Gb ram and up to 240Gb SSD. Would be great if something like this could be used as it is so compact . Also you can get a mounting bracket for it (as it is made to be attached to the back of a flat screen monitor). Thought it would be really expensive but is around £230..
26th Feb 2013 3:48pm |
cooler Member Since: 15 Sep 2013 Location: Wieliczka Posts: 10 |
Hi Matt, any news / progress ? |
27th Oct 2013 7:31pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi Cooler, to be honest the project has sort of been retired/moth balled at the present time. Issues with getting the physical factory screen buttons to interface with the software and the issue that there is presently no windows based GPS software that integrates fully with Ride Runner that is supported by manufactures anymore have but spanners in the works and as i am a complete perfectionist i could not install something in my car that did not look and feel 100% factory.
28th Oct 2013 11:27am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Apple TV sounds interesting - how are you powering it - with an inverter ? |
28th Oct 2013 11:34am |
yes using the existing 12v > 240v inverter thats already powering my playstation 2. I have had the Apple TV solution running on the test bench so going to fit it in the car today. Will post pics and a write up later.
28th Oct 2013 11:41am |
well Matt .. You are right, it's not the news i was hoping for .. ;(
28th Oct 2013 6:51pm |
iluha528 Member Since: 09 Nov 2013 Location: Moscow Posts: 1 |
Hi Matt! I'm already using Apple TV in my 2008 RR for 8 month. QVIF interface was used and a power adapter. Several HDMI cables (for rear monitors also) and HDMI splitter. Also installed WiFi router in the back of the car plus 4G modem. If you need any photos or have any questions you are welcome. BR Ilya |
14th Nov 2013 8:16pm |
