Home > Technical (L322) > TDV8 - Erratic Idle?
Jim_m_kidd
2015 Range Rover Autobiography SDV8 Loire Blue
Hi Folks,
Just wanted to ask if anybody has seen/is experiencing this 'problem' - asking because its been into dealer 3 times for diagnosis - had some software updates done and is now being described to me as being normal! Anyho before I cry BS I just wanted to check that this isn't something that my fellow FF owners are experiencing
I have posted a vid to youtube so you can see but basically I occassionally get what I would describe as a fluctuating idle. Normally happens after I've driven for a bit and then pull up - normally at lights or something so I'm on the footbrake and in drive - although have noted that shifting to N doesn't resolve it.
http://youtu.be/bvGfEqjWIS0
The rev counter seems to flutuate by ~25rpm (i.e. minor blip) and you can feel it in you bum (i.e. the engine is actually flutuating not just a dodgy guage)
Anybody else have this normal behaviour or had it and subsiquently found it was something wrong and hence ehat the fix might be?
Thanks for any help!
Post #172089 13th Feb 2013 8:00pm
