![]() | Home > Technical (L322) > noise??? |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
i think its my webasto heater but the noise it getting worse like a noisy vibrating fan it comes on and off for a second or two, the noise is from under the passenger floor well / bulkhead anyone else getting this noise it seems worse in the morning or when the car is cold |
anyone got ideas for a fix or had it happen to them ? |
Not sure as I've not had it myself. But, you're in the right area for the FBH as it's located under the battery tray at the back of the NSF wheel arch. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
In that location and at those times it's most definitely the FBH. It never sounds smooth or puuurrrdy, it just sounds like sounding grinding itself up into bits!
