Home > Technical (L322) > TDV8 Turbo problems |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
You have PM 2020 Porsche Panamera Turbo Hybrid (V FAST) 2017 Range Rover Autobiography 5.0 V8 2018 JCW Mini Cooper 2018 Skoda VRS |
4th Feb 2013 9:55pm |
Doesn't work as you need it to be pushing as hard as possible to clear it its more to do with the heat burning it off than anything else FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
4th Feb 2013 10:15pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
I am not talking stock cars, more the modded type with aftermarket electronic boost controllers, even after setting up a car on my close to £100K dyno we always road test to make sure everything is OK and its amazing in the difference between a dyno and on road conditions, we often get a higher boost reading in a higher gear than is healthy. One day your life will flash before your eyes......................................make sure yours is worth watching! |
5th Feb 2013 8:33am |
Real world and dynos are very different no matter what anyone says. Thats why it took me an engine and a fair bit of time to get my LPG mapping right and still never thought it was perfect but just stuck to base boost and still made 330bhp and a good dollop of torque from my coop FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Feb 2013 8:43am |
Modern ecu's have a lot of safety built into them, you get what you pay for. One day your life will flash before your eyes......................................make sure yours is worth watching!
5th Feb 2013 8:49am |
True but the LPG was running its own ecu just piggybacking the ignition pulses from the main one FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Feb 2013 8:51am |
STMVOGUE2010 Member Since: 23 Aug 2012 Location: Alloa Posts: 100 |
Don't think this ones right in the head!!! |
5th Feb 2013 12:38pm |
You wont get max boost for very long though in modern stuff. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Feb 2013 1:44pm |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2564 |
I suspect you will. They aren't all running 2 bar and revving to 8.5k ... |
5th Feb 2013 2:09pm |
Doubt it. Hook up a boost gauge and you'll see most peak quick enough but then settle back down just as quick and don't stay at FULL boost but reduced boost for a while.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
5th Feb 2013 2:17pm |
I see what you mean - it will peak and then drop/raise/hold to keep to the determined torque figure as necessary. You will certainly see the maximum boost figure in normal driving. |
5th Feb 2013 3:08pm |
True but you need it to be for as long as possible to get the kind of temps needed to burn some carbon build up off in a diesel engine.
5th Feb 2013 3:31pm |
I thought the Coop was a shop very popular in Switzerland I believe... |
5th Feb 2013 3:33pm |
This kind of coop silly
5th Feb 2013 3:58pm |
