Home > Technical (L322) > PARK HEATER REMOTE RECIEVER
johnbowling
having studied a few posts it is suggested that the wiring should be in place to retro fit a park heater to my 2003 4.4 pertol i can find the wiring in the front wheel arch for the webasto heater its self but rave shows the remote heater fob reciever ecu in the boot i have looked for the wiring but cannot find it anyone know the location of it on the early cars?
Post #169153 31st Jan 2013 3:31pm
mjdronfield
Just because the car has the heater does not mean it has the remote heat function. It was an optional extra.
I know yours has neither. What I'm saying is that my Td6 has the heater as standard, but no remote facility. It is a seperate thing.
So you have the wiring for the heater in the front, and nothing for thr remote bit. Sounds about right.
The ECU normally links to the remote bit attached to the TV tuner aerial I think.
There is some pics on here if you search for fuel burning heater, FBH or remote heat or such like.
I'll have a quick look........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #169194 31st Jan 2013 6:17pm
mjdronfield
Some info here ;
http://www.fullfatrr.com/forum/topic15995....fbh+remote
http://www.fullfatrr.com/forum/topic1024.h...fbh+remote
http://www.fullfatrr.com/forum/topic15276....fbh+remote
http://www.fullfatrr.com/forum/topic14073....fbh+remote
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #169196 31st Jan 2013 6:24pm
johnbowling
thanks for that didnt find all those posts and assumed mine would be an early loom plug found Smile
Post #169806 3rd Feb 2013 8:12pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
I've just installed the receiver in mine.
The small black plug is in the loom next to the rear fuse board.
I bought the receiver for £40 off ebay, the remote was £25.
I didn't buy the OEM aerial, i pushed a length of wire into the socket, it works up to around 50 feet!!!
Post #169810 3rd Feb 2013 8:47pm
johnbowling
now i just have to take the fuel tank down to see about fitting the fuel pump and line Sad
Post #169994 4th Feb 2013 2:05pm
