Home > Technical (L322) > Battery issue?
twhincup
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Battery issue?
I've read a few posts about battery/alternator based issues and was not surprised to get the 'hdc inactive' error message a couple of moths ago. A few days later I had a completely dead battery. As advised from here I bought the Bosch S5 battery, which is a sizeable lump and only just fits in the battery bay and the old one was not even half the size so no wonder it gave up the ghost. I was now left thinking thats the end of my battery issue for the next 200 years based on the size of the new battery
o..m..g that darn 'hdc inactive' message came back as soon as the weather turned really cold and i was pretty gutted, but the battery hasn't (fingers crossed) gone dead. so a scan through the forum on possibles and concluded its a drain overnight because once started in the day, i wasn't getting a repeat failure at all, so whats the cause?
Without fail everyday early in the morning (0530) i've been getting '(bong) hdc inactive' so racked my brain to think what could drain overnight, and whilst listening to steve allen on LBC had an idea .... the radio
I've physically switched the radio off overnight before switching off ignition and it may be an amazing coincidence but no 'hdc inactive' for the last 4 days
This may not work for anybody else, but it may be something to consider if youre having a battery drain. 2007 3.0L Diesel VW Touareg SE
2003 4.4 LPG, Vogue, Silver
Post #165193 16th Jan 2013 5:44pm
Thats an interesting observation. Thumbs Up
Post #165206 16th Jan 2013 6:02pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
@ twhincup I'll go along with what you said. Been having battery drain myself so took the car for a long (about 45 mins) drive last night and turned every thing off.
This morning got in a warm car (FBH on for 10 mins Whistle ) and started with no hesitation.
I even turned my screen off Thumbs Up
Post #165257 16th Jan 2013 8:46pm
Interesting, may be a solution to a few battery drain problems. How its doing it is unanswered but sounds
Like it could be the culprit. There is nothing that can't be fixed with a hammer😜😜
Post #165258 16th Jan 2013 8:49pm
could it be that that particular ecu is taking to long to shut down. ... - .- -.
Post #165263 16th Jan 2013 8:59pm
I've done some measurements on this and on my car I can find no difference in potential current drain between turning the radio off before or after turning off the ignition.
Based on the above it appears when you turn the radio off has no bearing on level of current drain once the car has gone to sleep.
Unless someone knows differently.....
One source of current drain I did find some time ago relates to the LR telephone installation.
I found a current drain of 140mA when the car was asleep on Fuse 22.
Removing the fuse reduced this drain to 0mA.
Given that I don't use the installed, now somewhat old fashioned telephone, removing the fuse seems to be a good option.
Post #165394 17th Jan 2013 12:06pm
