Home > Technical (L322) > Timed climate (heating) flattens my battery dead
356pilot
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Hello folks. I have an '09 RR Vogue: Pre-heating (no remote, just timer):
The last 2 times I've set my heating to pre-warm the car in the morning, I arrive to find the car is still freezing cold but the battery is completely dead (requiring a jump start).
My assumption would normally be a battery on its way out... but it never fails to start the car under other circumstances, when I often leave the car for days at a time and use it for short journeys with lights, wipers, seat heaters on etc.
I wondered if there is any other likely obvious problem which is causing the timed pre-heating to kill my battery whilst failing to warm the car at all?
Post #165213 16th Jan 2013 6:21pm
It is pretty hard on the battery. Unless it is fully charged up it will go flat after a few days, especially if you don't do a fair mileage to top it back up again day to day. My car will always start after not being used for over a week, but my wife only does about 10 miles a day. The FBH flattens the battery after 2 days use of around 15 mins. Previously..
Post #165216 16th Jan 2013 6:25pm
356pilot
Wow, so it really may just be using it when the car hasn't been driven for a while? I've had the car for two winters now, and it didn't do it last winter, but then it's entirely possible there just wasn't the right combination of lack of use / cold temp / me setting the climate timer.
Maybe I'll get the battery checked anyway before I shell out for a new one or for any other diagnostics. If anyone else has had this experience though I'd be interested to know.
Post #165217 16th Jan 2013 6:39pm
If there's a sure way to find out if your battery's less than optimal, this is the way to do it unfortunately.
A lot of people go to the bother (and expense) of getting their battery checked, only to be told it "looks fine", and then start experiencing "unusual" problems. Got - 2017 SDV8 Autobiography in Loire Blue
Post #165219 16th Jan 2013 6:49pm
