![]() | Home > General > NEXT RANGE ROVER MODEL YEAR 2010? |
wolf Member Since: 03 Apr 2007 Location: italy Posts: 5 ![]() ![]() ![]() |
Someone knows details about next IV generation RR? I heard something about 2010...isnt it' I hope Land Rover don t launch new model before 2010 because i just buy a TDV8 in jenuary...i wait 4 your answers...buy (from italy) |
VA Member Since: 25 Mar 2007 Location: Surrey Posts: 31 ![]() |
From what I've heard it will be 2010 depending on progress. The design has only just started I believe. |
shmoogle Member Since: 26 Mar 2007 Location: Mongolia (where the Mongs come from) Posts: 108 ![]() ![]() ![]() |
Which means it will likely collapse in a heap if you slam the doors too hard. Halfway Down The Stairs,
ENVOY Member Since: 25 Mar 2007 Location: up a track in the middle of nowhere Posts: 239 ![]() ![]() ![]() |
I thought it allready used a lot of alloy in its construction ![]() |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Only the Defender uses aluminium in the body these days Envoy. As far as I can remember from doing the factory visit there is no aluminium in the body of the FFRR, it's all very thin steel sheet pressings these days as it is stronger than aluminium in crash testing........................ |
Slimer Member Since: 26 Mar 2007 Location: disco3.co.uk Posts: 8 ![]() ![]() |
D3 (and presumably RRS and FL2 too) has an aluminium bonnet and lower tailgate, I suspect more will definitely creep into the construction of all LR's to reduce weight. |
Well you learn something new everyday, i was under the impression they were all alloy |
