![]() | Home > Technical (L322) > Air Suspension Inactive after D/S Front Bag Blew! |
That is a bit strange, mine was hanging with its nose on the ground when both front bags were replaced but needed no electronic "help" to get going again. I suggest to disconnect the battery clamps, hold them together for at least 10 secs. to drain the ECU memories and then reconnect to the battery. MY 2010 5.0 SC Galway green and sand interior!!
Durham4416 Member Since: 10 Dec 2012 Location: Middlesbrough Posts: 248 ![]() ![]() ![]() |
Hi mate try this item no on eBay, he only quoted me £40 to recalibrate my suspension as mine sits a little low at the rear, he is in Durham, unless there's someone on the forum who has the diagnostics to do it , the only reason I haven't paid to have mine done is because I'm not 100% it will cure it then It will be a waste of money so I was hoping someone had diagnostics who could help me |
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Have you driven the car since changing the air bag?
Tesh Member Since: 27 Feb 2010 Location: Co Durham Posts: 138 ![]() ![]() ![]() |
Ive used a guy in Haswell on numerous occasions for allsorts of jobs including suspension adjustments
That's the guy I linked to off eBay |
There is no such thing as an automatic recalibration . And you won't need it if all you've done is replaced the strut.
James
Cheers mate but I think it needs recalibrating, I don't think it has any faults it just sits about 4cm lower on the back, might be worth plugging it in first to see if there is a fault though ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35522 ![]() ![]() |
the back being lower than the front is normal afaik.... ... - .- -.
Yeah I think it's supposed to be 10mm lower, i used the guide on here and it's definiey to low at the rear, I'm hoping a recalibration is all it needs as the suspension goes up and down exactly how it should and it doesn't drop over night |
i suppose 4cm is a bit much .... |
