![]() | Home > Technical (L405) > Engine Noise Cancellation - SVAutobiography & PHEV |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 804 ![]() ![]() ![]() |
With the advent of PHEV vehicles, a particularly new issue is a low frequency booming noise, caused during charging of batteries using the internal combustion engine. During charging, the engine is operated at low rotational speeds and high loads, leading to pronounced low frequency noise. While in the past reducing low frequency noise either required large absorbers and/or heavy dampers, today the issue can be tackled by use of an Active Noise Cancellation system.
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
So perhaps this explains why the PHEV in Vogue trim comes with Meridian 825W as standard...
SY2020 Member Since: 18 Feb 2020 Location: London Posts: 2 ![]() ![]() ![]() |
Hi guys, newbie here but very interested to learn about the Active Noise Cancellation technology in the PHEV. Is this confirmed to be in all P400e? I have recently acquired one and on good days, I have to say, the car's has amazing sound insulation and minimal noise in the cabin. On "bad days", there is a booming low frequency resonance type noise which is very annoying. Reading your comments, I just wonder if some days the software is working well and some days the software simply mis-times the cancelling bass sound and it is very audible?
I have not experienced this. And I have not heard about the noise cancellation before or since. But if it’s true, once reason not to use it in marketing would be if it’s experimental and might go wrong... this was they don’t need to fix it. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso |
Mine is MY19 and yours MY20. Wonder if the MY19s have got this problem and MY20s not. I bought one in June 19 (Vogue SE P400e) and it had the issue. Upgraded to the AB in November 19 and same problem. Sigh. |
Lyonhead Member Since: 05 Aug 2017 Location: Cardiff Posts: 349 ![]() ![]() ![]() |
Ilard, Would you believe it, but, there is a system on the SVA that allows passengers voice in the rear of the car to come out through the speakers in the front as you travel along. Switched it off on day one and it hasn’t been on since ![]() ![]() 2016 RRS SVR Estoril Blue - Gone 2010 RRS 5.0 Supercharged Navara Bronze - Gone 2008 RRS 4.2 Supercharged Black - Gone 2006 RRS 2.7 Diesel Rimini Red- Gone |
Yeah, I have conversation assist too (ie Signature tunes), but even with it off I can still hear all the whining! I wonder if this is what’s masking my 4-pot drivetrain....
