Home > In Car Electronics (L322) > TouchScreen Satnav retrofit
Ibartsimp
France 2008 Range Rover Vogue TDV8 Buckingham Blue
Hi,
I have a facelift 05 SE that has touch screen with all functions but satnav. It tells me no satnav installed when I press the (hard or software) button.
It also has an antenna on the top (don't know what this means.
I'd like to fit nav in it but have to figure out what I need.
Is it just that: 2005 Land Rover/RANGE ROVER DENSO GPS NAVIGATION MAP READER CPU MODULE COMPUTER or do I need something else?
ps: I think I've deeply searched the forum and didn't find the info Wink thanks!
Post #162681 8th Jan 2013 8:06am
SteveMFr
Site Sponsor
http://www.fullfatrr.com/forum/post24931.html#24931
and look for the posts by mzplcg (Dom) here
http://www.fullfatrr.com/forum/topic2737.html
You might want to shoot Dom a PM as well
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #162692 8th Jan 2013 9:18am
Ibartsimp
wow, thanks, the second link is massive! I'm trying to understand what's written in it... but don't get for now a clear answer to my questions Wink
Post #162795 8th Jan 2013 5:39pm
tbh, the OE nav is ok but you could get a all singing and dancing tomtom for around £100... worth considering... ... - .- -.
Post #162797 8th Jan 2013 5:44pm
Ibartsimp
yes but a second screen... not fan, I already have my phone
Post #162798 8th Jan 2013 5:45pm
mzplcg
The short answer is yes, it is possible. However it is not exactly straightforward.
You would need a loom which I can get you the dimensions and connections for - you would have to make this.
Then you need a DVD unit, can be found on the bay for about €150. You also need a co-ax cable to go up to the roof fin, again you would have to make this.
Last you would need a diagnostic tool which can enable the feature in the CCF file.
Once you have all this it will take about a day to do the work. Seats out, carpets out, dash out.
Hope this helps.
Dom.
Post #162803 8th Jan 2013 5:56pm
Ibartsimp
Ok... Enlightening! Now I'm a big fan of the second screen Wink
I won't go through this work, for sure, I'm too newbie, time constrained (and lazy Wink)
I kind of had a secret hope that it would just be adding a DVD unit and enabling it but it's far from being the case...
And for the record, I had found a (much more complete) parts list here http://www.blackbox-solutions.com/IUI/Main_Parts_List.pdf, part of the excellent diary here http://www.blackbox-solutions.com/IUI/diary.htm
Post #162811 8th Jan 2013 6:11pm
rover024
Ireland 2008 Range Rover HSE TDV8 Santorini Black
Hi, Have not visited the forum for some months, fitted sat nav to 2008 RR HSE, got much help from members in forum.
Steve and Dom in particular. Same instructions have been posted for you. I was a bit anxious at times especially with dash stripped down, given that you could buy a unit for couple hundred Euro and stick it on the dash. But it was worth the effort and it works a treat, was in France in November spent a few days in Bordeaux, it worked a treat. I assume it has added value to the vehicle. The most difficult bit is securing the cable from the DVD reader in the boot to the dash,
it should be available in breakers.
If you need any further assistance feel free to contact me.
Regards Jack. Jack
Post #175063 28th Feb 2013 9:20pm
Ibartsimp
Do you mean a third party thingy like tomtom?
Thanks for the info, if you pass by around bordeaux again, you're more than welcome for a glass of wine + RR chat Wink
As for the modifications, I first need to get this http://www.fullfatrr.com/forum/post174998.html#174998 sorted out.
Had also asked some questions about plugs I have in the boot here http://www.fullfatrr.com/forum/post175103.html 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #175104 1st Mar 2013 8:02am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Rocking up to this thread a bit late.
If the originator has the Sat nav antenna ( sharks fin) and If he has the unit (black dvd player) on the left hand side of the boot. Is it not just the unit thats faulty?
I had the same message when mine broke replaced with one off of the bay of E all fine. When checking old one found water damage to the circuit board despite having water shedder fitted!
Now got extra sealing around it. Mine was a blue one! Smile
Post #175140 1st Mar 2013 9:26am
Ibartsimp
Not late, don't worry.
I have the Shark Fin antenna (could it be a dumb one?) on the roof but no dvd player and no connection loom either I think.
See here http://www.fullfatrr.com/forum/post175103.html
Can you picture your left & right side of the boot & do you have a touchscreen model (I guess so)? 2008 TDV8 VOGUE - Buckingham Blue on Sand
Post #175152 1st Mar 2013 10:07am
Googsy
Jack
Did you do all the work yourself? Like you I have a 2008 HSE with the Nav button but no DVD player etc.
Thanks
Conor Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #175160 1st Mar 2013 11:16am
