![]() | Home > Maintenance & Mods (L322) > Bottom Grills |
Took these bottom grills off this morning to get them painted, Then found out one is see through and the other is fully plastic backed.
If any other member gets a chance could he have a quick look to see if their's is the same as i think i will need to either cut out the backing of the covered ones, which i assume it is covered for a reason as the bottom of the washer bottle is behind it. Thanks in advance Gents ...... ![]() "Open Mike Night " sounded like a lot of fun until i found out i was going to an Autopsy |
Steady enough for handling something small ............ |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
hi, my ones are the same, how did you get them out as i want to paint mine silver, has any one come accross a grill that fits below the main grill..
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Mine are the same Mick. Did you contact Robert_it to ask how he did his? Discovery 4 HSE
Daveo just slightly push down towards the ground and pull out with your finger nails in at the top 2mins ...... |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
There must be an external temp sensor behind that grill.
fraid not , not a thing ..... ====================================
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Dremel? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
That's how Robert_it did his, he dremelled the holes out. Discovery 4 HSE
betty02 Member Since: 16 Dec 2009 Location: Blackpool - UK Posts: 16 ![]() |
Mick, if your going gloss black I would leave them in, better then getting stones hitting your water bottle and cracking it etc
Was thinking of doing them silver, but the notion has left me for the time being .............. |
Get me a frontal pic mate where you can see the grilles as well as the whole RR and I will have a play in photoshop if you want? |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2050 ![]() ![]() |
Mick
