![]() | Home > Maintenance & Mods (L322) > Headlight bulb replacement. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35508 ![]() ![]() |
bulbs can be replaced without taking the headlight out..bulbs can be brought from ebay for about £18 'ish and i would replace as a pair and keep the other good one as a spare.. ..try 6000k ones which give a whiter light.. ... - .- -.
ambulancekidd Member Since: 29 Feb 2012 Location: Ayrshire Scotland Posts: 276 ![]() ![]() ![]() |
Many thanks Stan, it doesn't sound so daunting as I'd thought. Strange thing is that the light was working when I went out to check it. I'll order two bulbs up this evening & fit them asap. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6416 ![]() ![]() |
And if IIRC, on the >2005 pre facelift, you can't remove the headlight without first removing the sidelight, you can't access one of the securing bolts on the outer lower side of the headlight.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
Stan, what heat range are the stock bulbs??? One day your life will flash before your eyes......................................make sure yours is worth watching!
stock bulbs are 4300k which give a slight yellowy tinge, 6000k are more whiter...
I prefer the higher temps like 6000 and 8000, do you have a part/model number for the bulb? Or a link to e.bay seller. One day your life will flash before your eyes......................................make sure yours is worth watching!
just standard d2s bulbs but they must have the metal anti vibration strips on them other wise they wont fit properly..
Are the bulbs the same part No in 2010> One day your life will flash before your eyes......................................make sure yours is worth watching!
dunno, you got a conversion then? ... - .- -.
Suuuure have BRO, I is goin all Council Estate wiv me ride innit |
sounds like a very interesting project .... |
Thanks Stan, so far ive done pretty much all the piano black I can inside inc heated piano black steering wheel, MKiv DVD Nav, re connolised the seats from sand to satin black as well as the lower dash and had the 20" RR rims reconned and finished in black chrome, hopefully by next week Ill have my IID tool and Intravee 2 as ell as the stuff I need to do the front end conversion, hopefully im well enough to do this myself at the workshop from my wheelchair, but I do fancy using some 6-8000K bulbs for that diff look. One day your life will flash before your eyes......................................make sure yours is worth watching!
Like this for standard fitting (but at 6000k) ?
Yes but for 2010> council estate headlamps One day your life will flash before your eyes......................................make sure yours is worth watching!
