Home > Technical (L322) > Drivers Lock - Key
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Drivers Lock - Key
Hi All,
I tried using the ignition key in the driver's door (2003 Vogue FFRR). It goes in and turns but it doesn't lock / unlock the door. I tired the spare key and that's the same. Both keys operate in the vehicle ignition OK.
I didn't really think much of it but then thought that if the only way of getting into the vehicle is via the remote plipper then what would I do in the event of a flat battery?! (which let's face it, is a very real prospect in a FFRR!)
Any thoughts from anyone?
Steve 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #161283 2nd Jan 2013 3:51pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Door card off and check the mechanism, Tried with spare?
Post #161319 2nd Jan 2013 4:28pm
SKOT
Hi,
Yes - Both standard key and spare both turn in the lock barrel but nothing happening.
I guess that this is therefore something wrong in the lock.
As mentioned, I dread to think what I would do if battery went flat as the other door has a blanked off key hole.
Next job is to take the door card off then............Ho hum, I was hoping there was a much more simple explanation! 2006 4.2 SC
Post #161322 2nd Jan 2013 4:33pm
Here's a video to help you:
rear one on the wiki .
Post #161324 2nd Jan 2013 4:37pm
CHANDOS
England 2005 Range Rover Vogue SE 4.2 SC V8 Santorini Black
Hi Skot,
I had exactly this problem on my 2005 car. Dealer fixed it and told me that there is a link arm between the lock barrel and the locking mechanism within the door and that it had become detached. Sounds simple enough to fix once the inside door panel has been removed, and that is never as simple as it looks. Good luck. Smile
Post #161334 2nd Jan 2013 4:47pm
SKOT
Excellent! Thank you very much all, much appreciated Thumbs Up 2006 4.2 SC
Post #161340 2nd Jan 2013 4:51pm
SKOT
All sorted - Thanks chaps Thumbs Up
If the battery had gone flat I would have been stuffed! (as per other live thread on here). 2006 4.2 SC
Post #164400 13th Jan 2013 7:29pm
