Home > General > how to change the date of my brake fluid service indicator |
Where is the brake fluid change indicator kept!? |
26th Jan 2010 2:25pm |
Robhibbert Member Since: 19 Nov 2009 Location: Uk Posts: 10 |
The date is shown when you first put the key in. Where the mileage for service is shown if you press the odometer button the date for fluid change is shown |
26th Jan 2010 2:32pm |
That's not for the brake fluid though.... That is the Oil Change and Inspection.
26th Jan 2010 2:47pm |
Why is the date changed every two years then?
26th Jan 2010 2:50pm |
Read the manual that came with your car before you start second guessing the info that I give. If you cant even be bothered to do that then don't ask the question in the first place if you already know it all! |
26th Jan 2010 3:00pm |
I dont know it all hence why i asked the question but i think you'll find it was you who started the patronisation with the exclamation on your first reply.
26th Jan 2010 3:07pm |
The RR has two or three levels of service:
26th Jan 2010 3:31pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
as dan said oil service , insp 1 and pos insp 2 brake fluid is every 3 years or at insp 2 which is same difference
26th Jan 2010 6:01pm |
