Home > Technical (L322) > FBH receiver location
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Another FBH thread Laughing
I've got the remote from eBay, but still not got it programmed and it's getting cold out there Crying or Very sad
I've tried removing the FBH fuse 59 as suggested by some without any success, and thought I'd try removing the supply to the receiver. I removed the rear fuse panel (as per TD6 location) but find only the PDC box.
Anyone know if the receiver for the FBH in TDV8 Vogue SE is lurking here:
or here?:
Or is it somewhere else?
Appreciate any help. Thanks.
Post #156818 11th Dec 2012 10:56pm
mafford
United Kingdom 2005 Range Rover Autobiography Td6 Santorini Black
I did mine this morning, if you remove the three screws holding the fuse board in on the first picture and gently pull the board out to give you a little more room to play with you will then be able to move the white siemens box out and behind that you'll see two connectors coming up from behind the board that the siemens box fits against, the right hand connector is black and I think has four small wires coming out of it - this is the connector that you need to remove for 5 seconds before reconnecting it and pressing the off button on the remote to pair the remote to the receiver. Took me about five minutes all in and then a toastie warm car this evening Very Happy
Post #156831 12th Dec 2012 12:25am
mafford
Mine's a TD6 - it might be different on yours, should be the same box but maybe a different position the receiver is quite thin and not much wider than a fag packet
Post #156832 12th Dec 2012 12:28am
its worth saying that not every td6/tdv8 has a remote receiver, timed/manual input yes but not a receiver.. ... - .- -.
Post #156859 12th Dec 2012 9:09am
simon1233
If you have a receiver it should be located on the rear side of the metal plate that holds the rear fusebox, directly behind the white siemens unit. on this picture you can see the power connector that you need to unplug (small multiplug right at the back with white/brown/red wires) next to the ariel connector (yellow plug) which runs up to the tv ariel on the drivers side of the car. I managed to do mine without having to remove the fusebox Thumbs Up
Post #156865 12th Dec 2012 9:22am
taskam
Thanks for your comments guys. I'll check at the weekend to see if I have the receiver installed.
Post #157073 12th Dec 2012 9:35pm
taskam
FOUND: FBH recever location
Took the fuse panel off again and found it where Mafford and Simon said. Easy when you know where it is
Remote paired first time and FBH fires up just fine. Now to do some trial runs to check battery can handle it.
Thanks again for your guidance guys :thumbsup:
Post #157507 14th Dec 2012 7:44pm
mafford
Enjoy! It's my favourite thing so far about the car especially in this weather
Post #157511 14th Dec 2012 8:03pm
