Home > My Range Rover > Never noticed this before, have you?
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Does the trim just leaver off?? ( leaves room to get big screwdriver!)
Post #51593 23rd Feb 2011 5:11pm
Of course it does, let us know how it goes.... Whistle Discovery 4 HSE
Post #51595 23rd Feb 2011 5:47pm
Jesus don't lever that off with a screwdriver you'll damage the glass underneath when i got mine repaired they had to put a new one on held with serious epoxy resin .......
If you are serious about taking them off best heating each panel first then either get a very thin fine strong wire try and get behind it and use a sawing effect.
That's how they took my old one off .......... Whistle
Post #51619 23rd Feb 2011 6:57pm
M44K TS
Just in case..
Tel: 0844 875 2501 2006 Mercedes CLS
1991 Retro-style Mini
But really finding it hard to fight the urge for a S/C...
Post #51628 23rd Feb 2011 7:37pm
Nickj
Autoglass are coming to replace my cracked front screen on wednesday so may aswell have a go before then!!
Post #51640 23rd Feb 2011 9:38pm
daveo
the trim is attached to the glass you can fit the the later glass with out the trim to the early cars no problem plus the later glass are ment to have digital aerials, when you get the glass it has all the new trim attached V8 facelift Range Rover Autobiography 22" wheels.
Post #51644 23rd Feb 2011 9:45pm
Nickj
So do you mean you can't remove it on early model. Had a quick peek and the plastic trim would pop off but theres another bit it attaches to. this looks quite intergrated to the window!
So i'd have to buy a later window or can the lower part be removed via heat/ wire etc?
Post #51787 24th Feb 2011 8:04pm
daveo
i think you will find that the trim is part of the window, if you thought you could remove it to look like the later one it will not, the window stops short. also you will not get the your side windows out without breaking them,
but if you can get your hands on a pr of new rear quarters they will fit no prob.. V8 facelift Range Rover Autobiography 22" wheels.
Post #51800 24th Feb 2011 9:13pm
Nickj
I was thinking i could remove it but not now, so thanks for stopping me ruining my side trims. would it be 05+ rear windows i'd be looking for with digital recievers?
Post #51801 24th Feb 2011 9:15pm
Vogue
it was dropped very very late on with the 06 MY, in preparation for the 07 vehicles - but be careful, the early 06MY have the trim, the late ones do not. What I am getting at is there will be two different part no's for 06.
The late 06 MY's also have the revised tailgate rubber button cover subject of a different post on here.
Post #51841 25th Feb 2011 11:15am
