Home > Technical (L322) > Strange revving fault - Transmission / Electrics / ECU? |
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 |
Welcome to the forum
23rd Jan 2010 1:17pm |
ngb13 Member Since: 22 Jan 2010 Location: Cheshire Posts: 19 |
Thanks
23rd Jan 2010 1:34pm |
I can only recommend that you call a transmission specialist but from what you have said it sounds like that could be the problem.
23rd Jan 2010 2:17pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
I had a not disimilar problem on my TD6 where it felt like the clutch was going (if it had a clutch, i.e then I thought it was the TC also)
23rd Jan 2010 7:25pm |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 |
Got to agree it sounds like maybe a slipping clutch.
24th Jan 2010 4:43pm |
Thanks for the suggestions, here's a bit more info -
25th Jan 2010 2:03pm |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
1) could the s/c belt be slipping
25th Jan 2010 5:42pm |
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 |
how many kilometers on the clock ?
25th Jan 2010 6:01pm |
Turns out it is the engine fan that I am hearing.
26th Jan 2010 2:42pm |
Thermostat done and seems to have cured the fan coming on when it shouldn't, however, it seems this fault wasn't connected to the HDC. Car is back in the delears for further investigation.
28th Jan 2010 1:21pm |
65k miles on the clock |
28th Jan 2010 1:26pm |
its been known that a not quite 100% battery can cause hdc and other electrical gremlins onto no6 Range Rover
28th Jan 2010 7:42pm |
New Bosch battery was the first thing I tried. |
28th Jan 2010 7:59pm |
the hdc is linked to the abs and the steering angle sensor have you had any faults with steering / repairs and have you turned the steering lock to lock while running to recal the steering angle sensor onto no6 Range Rover
28th Jan 2010 8:08pm |
