Home > Wheels & Tyres > SC wheel fit issue .... again!
Not feeling quite so smug about my winter wheels/tyres now! Decided this weekend was the right moment for the swap. Got myself all set up and then fell at the first hurdle. I now know that the SC bolts are bigger than the holes in my old winter wheels that I used to use on my 2002. I've done the searches on here and seen I just need a new set of the old wheelnuts - which should still fit the SC M14 studs. But will the old 19inch wheel from 2002 fit the SC? It seems to be fairly tight on ther brembo caliper, but I think it should clear, but when I tried it, the wheel didn't easily push back flat on the hub and I wasn't sure if the offset was different or if it was just a tight fit on the centre boss. Anyone know before I order the wheelnuts? Mike - MPx
Post #154915 2nd Dec 2012 6:39pm
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
When I did my research in to 19"s for a SC I found it had to be either TDV8 alloys or the ones I got from Compomotive. This was due to the size of the Brembos and the way LR get their wheels made.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #154947 2nd Dec 2012 8:24pm
Well it turns out the old standard 19" wheels do fit a facelift SC. I was strruggling to mate the hub and wheel faces because the centre locator rings are a tight fit, but once I got the right (small) size wheelnuts to fit the old wheel holes, it was easy to use them to wind the wheel on. So while it doesn't do much for the looks, I'm now sorted again for another winter on the right tyres. Got the wheelnuts and locking set from here if interested.
[/url]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Mike - MPx
Post #155673 6th Dec 2012 8:34am
