Home > In Car Electronics (L322) > Sat nav disc?
Sat nav disc?
Has anyone upgraded their 2007/8 LR sat nav disc to the latest disc.
Is it worth the cost lr charge.......
Not looking for copies etc, just wondering if anyone had the latest put into a 2008my car and wether there is any discernible difference. Presume it just gives map updates nothing else..... There is nothing that can't be fixed with a hammer😜😜
Post #153939 27th Nov 2012 8:54pm
I have just upgraded to the 2011-12 maps. I was hoping for a tomtom type look, but no, it's just as bad as it was before. I take it the maps are updated but I have not been on any new roads yet!
Pm sent. Previously..
Post #153942 27th Nov 2012 9:00pm
ollielloyd
United Kingdom 2005 Range Rover Vogue Td6 Java Black
Where you get it from?
I have 05 with updated touch screen nav, you just swap the disk?
Post #153984 27th Nov 2012 10:25pm
Pm sent. Turn the ignition to position 2, put the disc in, sit back and relax whilst it does it all itself! Previously..
Post #153989 27th Nov 2012 10:30pm
Got the 2012 disc, needless to say not installed it yet ..... Knowing my luck it will probably go tits up , only good point I suppose I don't use the sat nav so I won't miss it Laughing ====================================
Post #153992 27th Nov 2012 10:33pm
ollielloyd
Do does the new disk change nothing apart from updated roads?
Post #153993 27th Nov 2012 10:35pm
In a nutshell yeah , any previous updated disc's I have put in before that's all they have done Thumbs Up ====================================
Post #153996 27th Nov 2012 10:43pm
simon1233
new disks just update the maps, no other updates (like the new RR splash screen Big Cry )
And the map updates aren't exactly what you would call 'current' either... Whistle
Post #153999 27th Nov 2012 10:46pm
the 2011/12 disc will update the mapping and poi's and give you very subtle changes to the 'map' itself, nothing else..
please be careful mentioning where you can get the latest disc other than official sources, because as per forum rules this thread might get deleted. ... - .- -.
Post #154027 28th Nov 2012 8:35am
