Home > Technical (L322) > Key wont turn
Glm
Key wont turn
Hi all help req! Problems starting up ? Bought new battery and car will start,turn off and then key will not turn in ignition to start up ! If I disconnect battery and refit it will then turn and start up and then it won't start a 2 nd time until I disconnect battery again ? Will it be a trip to main dealers faulty ignition barrell ? Thanks for any help again ! Current tdv8 range vogue 07
Post #153670 26th Nov 2012 7:08pm
ebajema
That's the weirdest problem I have seen sofar. Just try the battery dis-connection procedure (Wiki) and hold the two clamps together (while they are off) for at least 10 seconds to reset all faults. MY 2010 5.0 SC Galway green and sand interior!!
Post #153671 26th Nov 2012 7:16pm
there can be a problem with the key mechanisium ....take the console off an inspect it , how to in the wiki i believe.. ... - .- -.
Post #153672 26th Nov 2012 7:17pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
Have you tried both keys?
Post #153675 26th Nov 2012 7:41pm
Glm
Tried both keys !can only start it up a 2 nd time when I disconnect terminal and then it will turn over! Current tdv8 range vogue 07
Post #153679 26th Nov 2012 8:17pm
Charmer
Did you manage to resolve this?
I can't turn my key in the ignition either.
I am charging the battery up at the moment as I think that is my problem. I have checked the battery cables and they appear fine.
Will try the battery disconnect next. Rolling Eyes
Anyone have any thoughts on what could be wrong?
Post #173786 21st Feb 2013 5:07pm
When you first put the key in, can you hear any of the locks disengage? Even when I have had a flat battery it still let's me turn the key. Have you tried both keys? Previously..
Post #173791 21st Feb 2013 5:29pm
Charmer
Both keys would not turn.
Charged the battery for several hours with a CTEK charger and still nothing. Confused
I have disconnected and reconnected the battery and after arming and disarming the central locking it is now working again.
I think it is battery related. I left the car unlocked for a couple of days and wonder if this was to blame.
I can see a trip to Euro Car Parts in the near future!
Post #173797 21st Feb 2013 5:58pm
Glm
Yes I changed the battery and no problem but when connected it up to computer it showed that the alternator was not charging he battery! Changed the alternator and have not had a problem! The battery has to have at lest 14 volts or the key wont engage ! I had to keep disconnecting battery every time I needed to start up until I changed the alternator ! Current tdv8 range vogue 07
Post #173806 21st Feb 2013 7:01pm
Charmer
Thanks.
I hope mine is just the battery rather than alternator. The car hasn't been used much over the last fortnight and I left it unlocked for 2 days.
At least I know my Tracker is working as I got a call from them within 5 minutes ofdisconnecting the battery! Laughing
Post #173810 21st Feb 2013 7:10pm
Glm
That's good as the alternator was expensive ! Best getting battery fully charged and go from there ! Current tdv8 range vogue 07
Post #173811 21st Feb 2013 7:14pm
Glm
Sorry didn't mention but it wouldn't let me turn the key before I charged the battery up only push it in ! Then nothing Current tdv8 range vogue 07
Post #173813 21st Feb 2013 7:15pm
Good thread Thumbs Up
Last edited by Gazellio @ Prestige Cars on 26th Jun 2013 6:07pm. Edited 1 time in total
Post #192499 7th Jun 2013 8:52am
is this the bit you mean?
http://www.fullfatrr.com/forum/topic18730.html ... - .- -.
Post #192501 7th Jun 2013 9:00am
Just interested.
Last edited by Gazellio @ Prestige Cars on 26th Jun 2013 6:08pm. Edited 1 time in total
Post #192505 7th Jun 2013 9:17am
