Home > Technical (L322) > Won't start, help.!!! |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Lolo
4th Mar 2013 8:23pm |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 |
You're electronic ignition switch is at fault. It simply isn't sending a signal to thr starter solenoid. I had this very same problem. Ask your mechanic to switch ignition on and bridge starter solenoid to battery connection on starter, If it starts the car then bingo, you know your fault replacement switch is £185 from LR.
5th Mar 2013 9:51am |
Did you ever get this resolved Lolo. I'm using your man for a service next week Present :2008 TDV8 HSE
30th Mar 2013 2:15pm |
