![]() | Home > Technical (L322) > operation of rear wiper |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
hi folks.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7878 ![]() ![]() ![]() |
I wish !!
im just trying to remove if from the equation with regards to a damp boot.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8704 ![]() ![]() ![]() |
Mine takes a little while to start spraying.
I'll have to do some further experimentation and read my user manual when i get home from work! cheers gents MY2010 TDV8 Vogue Ipanema Sand
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
You need a new non return valve, I have had to replace them in the L322s I've had. About £3 from any good motorists shop.
My manual states to hold the lever forward for the required duration of the wash.
Is the nrv under the upper trim. I had it off the other week, could have changed mine then..... There is nothing that can't be fixed with a hammer😜😜
non return valve sounds a good bet - cheers stewart
barracuda816 Member Since: 11 Jun 2012 Location: oxfordshire Posts: 213 ![]() ![]() ![]() |
Getting the trim off is very easy, if a little brutal.
Same problem I had the other week. Got a new NRV from dan. The price should be in his section, less than £5. Instant water now. Doodle to change. |
Mine is immediate, the pump only works on one stroke of the wiper...
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Sounds like the L322 is a bit like its owners.
