![]() | Home > Wheels & Tyres > Tyre Pressure sensing valves. |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 ![]() ![]() ![]() |
Hi All
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Just to throw a spanner in the works, just because the wheels have the TPMS valves in does not mean that the car has the system installed. My car came with some Land Rover optional 20 inch wheels which had the TPMS valves in them. The original spare 19 inch wheel in the boot has a normal 'rubber' valve and the TPMS system is not in the car. I believe that this may have been an optional system for all models, but am happy to be corrected if necessary.
Orange lamp on dash, left hand side of the pod.
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
Let the air out of the spare tyre and go for a drive, if it has TPMS it will tell you the check thespare wheel 56 TDV8 Vogue SE
Thanks chaps.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6748 ![]() ![]() ![]() |
TPMS is a nightmare, best thing you can do is turn it off with the IIDtool! |
I've been Jinxed.
By inflating the tyres to the correct pressure |
Went to my local Indi and he turned it off. no more trouble for me.
AJS4X4 Member Since: 08 Jun 2012 Location: Surrey Posts: 276 ![]() |
We see lots of trouble with TPMS valves through coroasion, the latest valves seem to be better. Andy....
