Home > Wheels & Tyres > Tyre losing 1 bar a day???
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
My Tyres losing about 1 psi a day, I'm guessing a reaaaaaaaaaaally slow puncture, will the guys at the local tyre place be able to find such a slow leak? Puncture, or could it be anything else?
Cheers
Post #151510 16th Nov 2012 11:01am
bead or valve leak or a nail in the tyre, the tyre chaps will sort it .... ... - .- -.
Post #151512 16th Nov 2012 11:07am
I bar a day is a lot.
Could easily be detected in a waterbath.
Could be a puncture or a bad rim seal.
Post #151513 16th Nov 2012 11:08am
mrblonde
Sorry all was typing after a night shift! I meant 1 psi a day *whoops*
Post #151527 16th Nov 2012 1:14pm
barracuda816
United Kingdom 2005 Range Rover Vogue SE Td6 Tonga Green
Does it have the tpms valves fitted?
Post #151530 16th Nov 2012 1:20pm
mrblonde
Barracuda
sorry whats a TPMS valve?
Post #151617 16th Nov 2012 10:04pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
TPMS = Tire-pressure monitoring system, it's an optional extra which isn't normally selected.
I also have a slow leak on my front tyres, so I presume it's the same thing with that being a bad rim seal.
Making a visit to the tyre shop tomorrow, I'll report back! Thumbs Up
Post #151623 16th Nov 2012 10:29pm
barracuda816
As above it is the tyre pressure monitoring system, looks like this
[/img]
Uploaded with ImageShack.us
The black bit is in the wheel.
The problem with them (well one of the problems anyway) is the alloy stem cracks with age, and either leaks or lets go completely, leaving the driver stranded.
Post #151668 17th Nov 2012 12:22pm
