Home > In Car Electronics (L322) > TV Arial on a 2007MY Supercharged ...
TheAllSeeingPie
United Kingdom 2007 Range Rover Supercharged Supercharged Java Black
Anyone know where it is? Apparently there is a fault with it (IIDTool) and also it gets jittery reception.
07 Supercharged - Still breaking her in!
Boot soundproofing part 1 - http://www.fullfatrr.com/forum/topic15612.html
Custom exhaust - http://www.fullfatrr.com/forum/topic15296.html
18" wheels for Brembo equipped cars - http://www.fullfatrr.com/forum/topic15052.html
Post #147867 24th Oct 2012 4:00pm
ebajema
First suspect would be the electronics in the left hand side rear compartment. Check for moisture and corrosion.
Not sure but thought the TV aerial was glued onto the side windows. Pre MY 2006 have the side window aerials and aerial amplifiers just underneath that for what I can deduce from the workshop manual (PDF) that i have here. MY 2010 5.0 SC Galway green and sand interior!!
Post #147868 24th Oct 2012 4:11pm
Yes Side rear Windows and rear window.
1 Side window television and radio diversity aerials 2 FM aerial amplifier
3 Side window television aerial
4 Television aerial amplifier 5 Television aerial amplifier with parked heating
6 Suppressor
7 Suppressor
8 Television aerial amplifier
9 Side window FM aerial diversity amplifier The “RDS radio” system uses the heated rear screen element as the radio antenna. The signal is processed by an
amplifier before being passed through to the head unit. This antenna and amplifier is also used receive and process
signals from the remote handset to lock/unlock and arm/disarm the alarm. Because of this there are two types of
amplifier to accommodate the different frequencies used with the remote in different markets. This standard amplifier
is located in the tailgate at the top left hand corner. The “RDS Hi Fi” system use a second antenna fitted in the left hand window of the luggage compartment to achieve
the diversity function. The amplifier for this antenna is located left hand side of the luggage compartment behind the
trim panel near the wheel arch.
Post #147881 24th Oct 2012 4:40pm
TheAllSeeingPie
So if the arial does turn out to be Censored it's a windows out job? Or can I peel it off and stick a new one on? :/
Post #147910 24th Oct 2012 6:26pm
i would check the connections first, might have oxidation causing the error. ... - .- -.
Post #147912 24th Oct 2012 6:29pm
TheAllSeeingPie
Well hopefully tomorrow is the day I fit the Seat Heat/Cooling ECU, so I'll have a look at the connections at the same time. I assume all the bits are on show and I don't have to go digging to find them?
Post #147915 24th Oct 2012 6:32pm
ebajema
My money (not that i have a lot of it ;() is on connections. Time, humidity and electrons have done their destructive work so it is highly likely that you have some issues with corrosion. Just undo all the connections, clean them, spray them with contact cleaner and see if that resolves the issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #147922 24th Oct 2012 6:46pm
