Home > In Car Electronics (L322) > Remove and replace TV Tuner
Cash2
United Kingdom 2018 Range Rover Autobiography TDV6 Santorini Black
Guys
I have searched the various threads and can see lots about changing the TV tuner to a digital or hybrid unit but cannot find out how to remove the installed unit already in the FFRR, can anyone shed some light please?
I have a hybrid module it all works as I have tested it without installing it but just cannot fit it next to the existing one as there is not enough room.
Any help and advise welcome ( after searching so hard for the unit now tro get stuck here not good ).
Many thanks
Post #147020 19th Oct 2012 3:01pm
does not the hybrid unit replace the analogue one? ... - .- -.
Post #147024 19th Oct 2012 3:06pm
Cash2
Hi Stan, yes it should but I want to know how to get the analogue unit out - that is where I am stuck..
Post #147025 19th Oct 2012 3:07pm
okey kokey, stick "hybrid tuner" [with quotes] into the search engine, there's loads of info there.. ... - .- -.
Post #147029 19th Oct 2012 3:13pm
Cash2
Thanks Stan will do and let you know the outcome.. ( positive I hope )
Post #147031 19th Oct 2012 3:17pm
Cash2
Stan all done and working, I have tackled harder jobs but not in such a cramped space.
You have to remove all of the units to be able to remove the tuner to replace it, all I can advise is to take care with the cables as some are copper and some are fibre which should not be bent to much.
All in all a worthwhile exercise.
Thanks alot
Post #147062 19th Oct 2012 5:10pm
glad its sorted... Thumbs Up ... - .- -.
Post #147082 19th Oct 2012 6:43pm
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
i have had the hybrid TV tuner fitted in both of my FFRR's without removing the old analogue unit, it's a piece of cake to fit.
all you need is to remove all the connections from the old unit first, then using heavy duty self adhesive velcro stick one side to the old unit the other side to the new unit and lower the new hybrid into the gap and stick them together.
it will not fall off, i have done loads of road and off road miles and it stays right in place. infact when i wanted to remove it from my TD6 when i bought the TDV8 it required quite a tug to seperate the units, but saves messing about removing the old one. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #148530 27th Oct 2012 6:05pm
