Home > Technical (L322) > Heated windscreen issue.
JoyZipper
Good morning all.
I own a 2002 L322 4.4 V8.
Now that the colder weather has arrived I have had to use the heated windscreen a couple of times recently. However, it only seems to heat up about 25-30% of the windscreen (in patchy straight lines from bottom to top).
Is there a quick fix for this ?
Post #146552 16th Oct 2012 7:48am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Yes - Hammer to the glass then call Auto-Glass for a new windscreen.
Sounds like the heating element has broken.
Post #146558 16th Oct 2012 8:07am
radical , but what simon says is a solution... Laughing ... - .- -.
Post #146560 16th Oct 2012 8:17am
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Only half of mine works. Sadly it's the passenger side that works Sad No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #146787 17th Oct 2012 10:45pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Ring your insurance and tell them you switched it on this morning when cold and there was a cracking noise
And now the window heater doesn't work, they will pass you on to the window company who will charge you about £65-70
Not affecting your no claims.
Don't break the glass as it will make a mess and its easier for the window guy to take out in one
I did this last winter when part of the drivers side wasn't working but passenger was fully working Thumbs Up RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #146867 18th Oct 2012 3:48pm
