Home > Technical (L322) > help again please
This topic is locked: you cannot edit posts or make replies.  Down to end
Rockportpurple
2002 Range Rover Vogue 4.4 V8 Giverny Green
help again please
hi guys
well picked the car up ran ok for 23 miles then no poing no warning message nothing but only 3 gears wouldnt change into 4 or 5,and approaching junctions roundabouts a shunt down change,
same symptoms as before
has anyone got an idea what this fault could be,the car is going back wed for more in depth diag but iv change the battery,potentiometer on the gearbox,fluids changed,when its running its fine bt then it goes duwappy,,come home turn of the key restart it runs fine then after a period of time same fault,,
i was giving the car a decent push with the throttle pedal up to around 80 at the time
if anyone has any other ideas please help
regards
clive
Post #145353 8th Oct 2012 5:25pm
you need to carry on your existing thread on your problem so that we can see what has been already suggested ..
thread locked.. ... - .- -.
Post #145355 8th Oct 2012 5:33pm
This topic is locked: you cannot edit posts or make replies.  Back to top
