Home > Technical (L322) > Body Panel Materials
There are two bits IIRC, ones for the lip on the body to bumper section and the other is from an RRS that fits the Body-Door section which is often the biggest rust spot... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #145554 9th Oct 2012 1:25pm
roger 47
United Kingdom 2017 Range Rover Autobiography SDV8 Fuji White
Ok, I've finally fitted the protective rubber strips now the rain has stopped.
This is the top strip which is the LR part for the FF.
This is the front of the wing edge with the door closed, I purchased some rubber door edging from fleabay. I filled the rubber edging with waxoyl and pushed it on.
This is with the door open. I'll wipe the excess off tomorrow.
I also looked behind the wheel arch protector for any rust and found none. Thumbs Up
Post #147056 19th Oct 2012 5:35pm
mjdronfield
Sorted.
That should keep the crap at bay.
Looks pretty much what I got, but without the ridges.
If you are unhappy with the wheel arch near the door at any point, you could get some more of the LR part and cut to length.
Thats what i ended up doing.
Looks good - nice and tidy, and should have been fitted from new - LR Boneheads !! 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #147059 19th Oct 2012 5:51pm
