Home > Technical (L322) > Supermarket fuel
Page 2 of 3 <123>
Shocked Whistle Have never used them and never will! w Censored s Shocked
Craig Whistle
Post #142435 21st Sep 2012 10:58pm
I wouldn't say our refinery is better than others. I would guess the big thing would be the forecourt storage. There all open vented tanks so moisture can very easily get in there. The stuff the supermarkets buy are all stored I would imagine in the same tanks. I don't know the specifics of contracts etc but can't see each customer having their own tank for storage. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #142444 22nd Sep 2012 7:28am
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Both the TDv8's I have owned ran noticeably quieter, smoother and about 2-3 mpg better on Shell and BP regular diesel than on the local Sainsbury's stuff. The 2.2lt 4 pot in the Evoque doesn't mind what it gets fed, it runs well on any of them, regardless of brand though it still gives worse economy than it should!. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #142448 22nd Sep 2012 7:44am
ebajema
On tank storage, in hydraulic tanks one usually uses breather with desiccant in it to keep the hydraulic oil clean (major cause of damage in hydraulic systems). I can imagine that cheaper storage tanks won't have proper breathers or the desiccant is not used or doesn't work anymore (not changed in time). This causes moisture to be drawn in due to temperature differences (the tank "breaths") the condenses in the tank, especially when the fuel levels are low. That water mixes with the fuel and problems start.
And that is without someone adding water on purpose.
And then there is of course the filling of the tank, where water can get in, or with underground tanks that ground water or rainwater gets in due to bad caps/breathers/valves etc. MY 2010 5.0 SC Galway green and sand interior!!
Post #142449 22nd Sep 2012 7:46am
+1 Thumbs Up [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #142455 22nd Sep 2012 8:34am
mjdronfield
Without sounding stupid, would Esso count ?
Have one of those fairly near, but can't think of a Shell or BP, but then again, I wasn't looking out for one.......
May have to use the old web to see what non-supermarket is nearest.
Always used supermarket fuel, but will try alternatives now.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #142470 22nd Sep 2012 9:52am
The nearest Shell or BP to your local supermarket will probably try to price match. Those in our part of Hertfordshire do so best of both worlds....
ESSO & Texaco etc should also be OK but I reckon Shell & BP are the best on addatives that help MPG & Engine fitness.
Post #142478 22nd Sep 2012 10:07am
LostInSpace
New Zealand 2006 Range Rover Vogue SE Supercharged Java Black
Another vote for BP or Shell for both petrol and diesel. Both the SC FFRR and 928 feel smoother on their higher premium fuels. Haven't noticed and detectable difference in our Clio diesel commuter, but have had three separate instances over the last couple of years ago when using supermarket diesel of water contamination shortly after filling up.
Don't have any supermarkets with fuel near us, so the local BP is expensive Sad 2006 Supercharged
1990 Porsche 928 GT
Post #142485 22nd Sep 2012 10:23am
LostInSpace
New season of 5th Gear last night (now on Sky Discovey) did a fuel test using a Golf GTI (petrol & turbocharged) of various different fuels. Can't remember all the details, but cehapest fuel was Asda 95, most expensive was Shell Optimax, with the Shell giving 5bhp more (235 vs 240). 2006 Supercharged
1990 Porsche 928 GT
Post #142874 25th Sep 2012 8:09am
BrianC
If it was a mk6 gti then it's supercharged and turbocharged.
My wife has got one and I don't notice any difference on power etc where we buy our fuel but from now on i think I'll stick to the bp
Post #142883 25th Sep 2012 8:25am
But no real noticable gain in driving.
I'd like to seem them compare Diesels and and maybe through a set of BioD in as well for good measure... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #142885 25th Sep 2012 8:28am
mjdronfield
Saw that. Much better now its an hour long again (well, 42 mins).
Quite interesting, but only seems to show what these tests have shown for years, you pay a bit more and get a bit more power.
The Golf was a TSI.
When I ran my M5's I used both supermarket and premium fuels, and found the car to run smoother and a bit more throttle response with the premium fuels, but it was very subjective.
Prob the only thing that'll make me put Esso in the Td6 is if any fuel savings cover the extra cost per litre.
Shell and BP garages are miles away........ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #142893 25th Sep 2012 8:38am
Stormin
2003 Range Rover HSE Td6 Epsom Green
For ages ive been buying morrisons fuel, for my £5 voucher, however ive now moved my place of work which involves driving past a Shell Station. As the shell fuel was the same price i thought i would give it a go.
To be Honest i couldn't tell the difference neither did it make any change to my fuelly results.
So im back collecting my £5 vouchers.
I didnt try the super fuels, only the 95 RON Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #143023 25th Sep 2012 4:52pm
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
I dont have an Esso garage nearby but I'd certainly use an one as opposed to any supermarket fuel. I'm doing an awful lot of miles in a week & am fueling up every second day. I cant feel any difference in the performace on the supermarket fuel but as I've stated its the MPG that shows exactly what is happening. The MPG gauge is on the screen constantly, that why I noticed the difference. In my FFRR the driving varies so much that I hadn't noticed any real difference, but I will not put supermarket fuel back into my FFRR.
The only way I'll know what effect it has on the FFRR is when towing our twin axle caravan (1830kg) & I know that on supermarket fuel I get 20MPG when towing, so I'm looking forward to trying that with my new found information.
Robert. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #143085 25th Sep 2012 9:50pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
not super useful for you guys, but there's probably a similar list available for UK:
http://www.toptiergas.com/index.html
I use Conoco exclusively. There's a crap-load of Conoco stations around here.
I filled up the FFRR the other day, $92!
(56.82GBP)
That's expensive for US; it was close to $4 per US gallon.
So, 2.47GBP per US gallon, or 0.65 per liter.
I guess I should probably just shut up now, huh? Whistle Jim
2000 NAS HSE
2005 NAS HSE
Post #143097 26th Sep 2012 3:33am
Page 2 of 3 <123>
