![]() | Home > For Sale & Wanted > 2006/2007 Range Rover TDV8 or 4.2 Supercharged Wanted |
Real RR Member Since: 13 Aug 2009 Location: In a Defender Posts: 33 ![]() |
J, Here's my 2 bobs worth. Last query first. Personally I've bought and sold nearly 40 vehicles over 32 years of motoring, some new, some used, some good and some bad. My advice now is if you can afford it and want a better chance of picking a good car then stick to 1 owner vehicles. The original owner paid a lot of money and tends to treat the car well. They nearly always have a full history. The more owners a vehicle has had, the more cloudy it's history becomes. For some reason the more owners then the more modifications it has had. Only buy standard. This applies to all cars but is paramount with a RR purchase. And then don't modify it if you intend to sell it again. Lifespan - The Diesel engine used to be a purely mechanical cast iron lump which would run forever with basic maintenance, whereas Petrol engines were highly strung things often made of alloys, with electrics, carburettors, points and plugs, all needing frequent maintenance to keep them running. This is no longer true. It's now the other way around. The diesel is much more complex and thus likely to fail expensively. I've owned many diesels and prefer their character, but they don't make financial sense any longer. For me diesel now only has 2 real advantages, greater range on a tankfull and less volatility if you're carrying fuel. So if you are prepared to pay the money in depreciation for a car under manufacturers warranty, then go diesel. If not then petrol is now the way to go. As to longevity, I recently sold my P38 4.6 HSE with 205,000 miles on the original engine, still running sweetly and trouble free with a lot of life left in it. Although I was comparing TDV8 to Supercharged in http://www.fullfatrr.com/forum/topic949.html it also largely applies to diesel v petrol. TD6 is not in the same league as the SC, but if I HAD to buy diesel as a long term proposition I'd go TD6 rather than TDV8. And I would not buy a RRS regardless........ ![]() HTH. |
ukrangie Member Since: 20 Jun 2009 Location: Kent Posts: 520 ![]() ![]() ![]() |
If you are able to up your budget a little, there is this one
#Fair enough. The third one may be up your ally?
J600.COM Member Since: 27 Dec 2009 Location: North East Posts: 113 ![]() ![]() |
I spotted that buckingham blue one, looks just about perfect other than a couple of minor things (i know beggars cant be choosers) but im not keen on the buckingham, im not 100% on the wood (I was hoping for the black inserts) and finally im still not 100% sure whether the all black leather works on a dark car - i dunno what it is, but a black car with all black interior seems like its missing something, like it needs a subtle accent colour to set it off.
Again this is based on the RRS I looked at, black leather on the FFRR might be a different matter? |
It's not that its a cheap car, it's down to the Depreciation factor on the FFRR's, have seen a nice Giverny Green with two tone Leather SE .
I've found an absolute belter, 1 owner from new with only 33k miles on the clock £27,499. Its slightly over budget (only slightly) so perhaps with a haggle it might come down?? Don't even know if dealers haggle nowadays?? The only slight snag is that its got the charcoal interior |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2051 ![]() ![]() |
Being that fussy I'd look at something else or up the budget.
Besides the car supermarkets, most dealers will haggle. I managed to knock off a bit more than 10% of the asking price. That is unless you suffer from...
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Did the early SC's come with the Grand Black Piano wood? I thought that was introduced on the interior remodel for the 2007MY? Discovery 4 HSE
The doc Member Since: 25 Mar 2007 Location: In car hell :-( Posts: 425 ![]() ![]() |
"I've found an absolute belter, 1 owner from new with only 33k miles on the clock £27,499. Its slightly over budget (only slightly) so perhaps with a haggle it might come down?? Don't even know if dealers haggle nowadays?? The only slight snag is that its got the charcoal interior but other than that it looks perfect."
there aren't any look |
