Home > In Car Electronics (L322) > Range rover screen Monitor
jules64
United Kingdom 2004 Range Rover Vogue SE Td6 Bonatti Grey
Hi does any body know how to remove the Folding type monitor on a 2004 td6 it has gone blank! and i think the CCFL (back light )has gone .According to the web it is a E38 E39 5 7 SERIES NAVIGATION GPS SCREEN MONITOR.
Post #140478 10th Sep 2012 4:43pm
daveo
i would check at the back first, look for water damage around the nav unit, check the blue and white plugs on the tv tuner, can cause the same prob,,, V8 facelift Range Rover Autobiography 22" wheels.
Post #140502 10th Sep 2012 6:11pm
SteveMFr
Site Sponsor
And if that brings no joy then check youtube for a video by PowerfulUK on removing the head unit
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #140535 10th Sep 2012 8:51pm
jules64
Hi Dave, thanks for this , but which is the TV tuner ?.I have identified the GPS unit and the audio Amplifier.
I now thick the back light is ok on the screen as i can view the backlight under a blanket.
This car did have some water damage, but we have cleaned it all up.Is there a way we can test the monitor unit , before we buy a replacement.
Post #141596 17th Sep 2012 3:58pm
mjdronfield
It looks like this mate ;
Can't see the issue being the actual monitor. More likely to be the connections on the units in the boot.
Actual monitor failures are quite rare I believe.
I'd unplug the connections and make sure they are good, and then reconnect.......
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #141598 17th Sep 2012 4:09pm
jules64
Hi Mark,
Hi All, thanks for this valuable info , but after cleaning the connectors which looked fine , i still cant see any video on the monitor only what appears to be the back light turning on when viewed under a coat:).Getting back to the monitor there appears to be a small LED light in the middle of the unit that does not light up (we are not sure of its purpose and wondered if it was connected with the fault)?
thanks J
Post #143637 29th Sep 2012 9:17am
mjdronfield
Sorry mate, a bit beyond my knowledge now..........you could have a seach on the BMW forums to see if anyones had a similar issue, as its all the same kit.
You would have thought there may be a test you can do from the front, by pressing certain buttons, like a test page, but I don't know of such a feature.
There is a video on youtube / powerful uk about how to get the unit out, if thats any use to you in the future........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #143700 29th Sep 2012 6:43pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Jules,
It's defo the box in the boot. Mine has done this as few times. Take the box out of it's holder, give it a tap or two and plug it back in. Works for me.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #144247 2nd Oct 2012 2:38pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
Hi jules 64
The small led is not an led its a photocell that changes the screen brightness automatically RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #144837 5th Oct 2012 1:51pm
The photocell was "supposed to" adjust brightness but was disabled at some point because it just didn't work!
Mine doesn't (2002 model) work, tried finger over it or shining torch in the dark, no change..... .
Post #144845 5th Oct 2012 2:52pm
