Home > Maintenance & Mods (L322) > Trans cooler pipe removal
jay-p
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
How do I get the pipe off?????? Looks like an air fitting but it just wont come off, is there any particular technique?
Sorry to start a new thread but I need to get it off today Sad
Post #138451 30th Aug 2012 8:31am
goldsax
United Kingdom 2011 Range Rover Vogue 4.4 V8 Ipanema Sand
had my car at 4-tech today to get an oil flush.
the pipe had to be cut because the fitting you are talking about is next to impossible to remove.
and if by any chance you do manage to take it of, an accurate /sealed re-fit is difficult.
the pipe is easy to cut and to reconnect a brass/metal connecter(like a pipe a bit bigger then the internal diameter of the cut rubber hoses) is put to connect the two hoses together and tightened with 2 jubilee clips at either end.
Post #138569 30th Aug 2012 7:21pm
jay-p
Sorted Cool it did come with problems though, although I have completely flushed it at a cost of around £90 Very Happy
I couldn't get the connector off so I did something I can't believe I didn't think of before, I just followed the pipe back to the gearbox and took it off there, connected some hose and fed it to a bucket Thumbs Up ( I did manage to follow the wrong pipe back to the box and pump fluid all over the place first though Embarassed ) all it left me to do was fill the sump, run for 10 seconds then repeat till the fluid is clear Wink
Also fit a new rad today, gona go for a drive tomorrow and report back Thumbs Up
Post #138595 30th Aug 2012 8:48pm
jay-p
Just to report back if anybody was interested, my gearbox is fine now Cool the grumble noise has even gone and the point at where it used to chug slightly it now changes gear instead so happy days Wink I used 12L to flush it which admittedly wasn't enough, the fluid wasn't completely clear but it was almost there, I didn't have anymore fluid so I didn't risk dropping anymore out, in around a month I will do another flush but this time with 16L just to make sure, now I've got a method of flushing sorted it will be a 20 minute job next time Very Happy
Post #138939 1st Sep 2012 6:05pm
Method and pictures would be helpful next time around Smile .
Post #138977 1st Sep 2012 9:26pm
jay-p
The method is very basic, as in my last post above Cool
I will take pics next time, but basically h Cool heres what I did -
*Warm up
*Stop engine and remove drain plug
*Replace the plug
*( this step is a very risky chance I took and was at my own risk, I put in 1L of neat TFR and left for 1 hour )
*Drain the tfr
*Put in 1L of ATF to flush the pan ( repeat till clean when draining)
*Fill the pan with ATF until overflowing
*Remove the return pipe from the gearbox ( this is a steel pipe thats on the drivers side of the box above the pan)
*Fit 1 meter of hose pipe to the steel pipe, put the pipe into a container
*Start the engine for around 5 seconds and watch the colour of the fluid
*Top up the fluid
*Run for 5 seconds
*Repeat the above until the fluid runs clear
*Re-fit the return pipe
*Top up as usual ( move selector from N - D - N - R - N ) ( Dont quote me on this step but I think its right )
*Go for a drive, check level in N
With a good pump to get the fluid in quick this can be done in less than half a hour and around £100
Post #138984 1st Sep 2012 10:08pm
