Home > Technical (L322) > Homelink retrofit
JFR
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
Homelink retrofit
I have just bought a 2012 Range Rover 4.4 diesel Autobiography. It does not have 'homelink' and the dealership says that feature cannot be retrofitted. Is that correct, because I would have thought the wiring loom would have the necessary connections? Alternatively has anyone other suggestions?
Thanks
Post #137658 24th Aug 2012 8:13pm
Find it strange an Autobiography specced model never came with it , I have it on the (cough) lower specced Vogue SE model Whistle
Not to sure if it can be retro fitted tho ... Sure someone on here will know Thumbs Up
Post #137694 25th Aug 2012 4:41am
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
It should work as the unit is self contained in the rear view mirror. All that is required is the power supply which is shared by the electrochromatic function. It should be a straight swap for your old one... 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #138438 30th Aug 2012 12:23am
