Home > In Car Electronics (L322) > Venture cam
stu
United Kingdom 2012 Range Rover Vogue TDV8 Orkney Grey
you just need a small electricians scredriver or the likes to split the casing apart. it's a while since i did mine, but if i remember correctly there are two or three, little tabs, one either side and one at the top perhaps that help retain the two halves together. if you break them when taking it apart it makes it difficult to seal it back up properly.
i bought two packs of tesco own brand rechargable AAA batteriesto make the battery pack up with. just take note of how they are held together and be handy with a soldering irion to make your new battry pack up.
sorry can't be more helpful or specific about things it was earlier this year that i did mine and i just went ahead regardless as it was a cheap one i bought from ebay to use as a spare if it could be repaired.
good luck anyway. Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #142367 21st Sep 2012 4:38pm
this thread shows the inside of the cam, might help.
http://www.fullfatrr.com/forum/topic5313.h...p;start=15 ... - .- -.
Post #142373 21st Sep 2012 5:20pm
Brewster
England 2006 Range Rover Vogue SE TDV8 Buckingham Blue
Many Thanks Stan and Stu I'll give it a whirl
just as soon as I've refurbed the back calipers .... main dealer serviced 6k ago new discs and pads found out yesterday calipers all but seized on their pins ..... still what do you want for 400 quid !! Confused
cheers ...Always time for a brew !!
2006 TDV8 Vogue SE
Post #142689 24th Sep 2012 10:47am
