Home > For Sale & Wanted > Tie rods and Track Rod ends
ambulancekidd
Scotland 2005 Range Rover Vogue Td6 Oslo Blue
You just need a large shifting spanner or pair of stilsons. The inner tie rod comes apart really easily as its always coated in grease.
Thumbs Up The reason women's minds are cleaner than a mans mind is that women change their minds more often!
When women say fine a mans in deep doodoo as fine has so many meanings.
Post #190857 27th May 2013 9:45pm
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Ok though not keen on adjustable wrenches to be honest. Just hoped someone would know in case it was a funny size.
Cheers though
Post #190858 27th May 2013 9:59pm
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Others have said tom but they will be well siezed (Landrover cant afford a penny per car in copperslip)
A lot of luck and big stilsons or get the inner and outer and save yourself the grief! Mine was a blue one! Smile
Post #190875 28th May 2013 8:57am
tomthevet
I am changeing the inner and outer. I meant to hex section on the inner steering rod where it attaches to the rack.
99.9% sure the lash in the sherical joints between inner and outer is the source of my knocking.
T
Post #190994 28th May 2013 5:09pm
ambulancekidd
The inner tie rods are behind the rubber boots & soaked in grease so they'll come apart really easily. Dont worry about a shifting spanner, the tie rods are really easy to undo with an adjustable spanner & you wont damage them by doing so.
Remember that you must keep the ring that goes over the end of the track rod end itself. I'd recommend that you just put an angle grinder through the old shaft because its highly unlikely that the nut on the track rod end can be undone. Repack the inner ends with grease when rebuiilding. The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #190999 28th May 2013 5:46pm
Andy3681
^ what he said. I got new locking rings with the new inner and outer track rod Mine was a blue one! Smile
Post #191000 28th May 2013 5:50pm
tomthevet
I was asking as the boots on mine are totally disintegrated so there is minimal grease in the spherical joint or around the hex section buts cool will see when i do it what size it is.
Cheers
Post #191001 28th May 2013 5:53pm
ambulancekidd
Please keep us informed with results mate. Thumbs Up The reason women's minds are cleaner than a mans mind is that women change their minds more often!
Post #191106 28th May 2013 11:02pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I just spent a day trying to get the one of the track rod ends off the tie rods. Even with angle grinder refused to budge. Then did a search and found this thread.....ordered the new tie rods and got both sides done in half a day! Once again, a great site for info.
Stan, this thread should be on the wiki ! 2007 TDV8 Vogue SE Java Black
Post #248431 15th Mar 2014 10:45am
